Hello TFP
I have been reading TFP materials for the past few months and have been dipping into Pool School. Thank you all. You all seem waaaay smarter at pool care than i am or ever will be. I have been trying to SLAM and then dunk myself. I swim about 4500 meters in this pool each day, that is. The SLAM seemed to work, and then the algae returned within lass than 36 hours. I wipe and rub and sweep and use a long brush and dive down with a scrub brush more than once a day, and the ring returns, an olive-green thick algae ring where the pool becomes deeper, all along the sides and at the deep end. This is a 1962-built, old, in-ground pool, 12,000 gallons, shallow with steps at one end and approx 9 feet deep at the deep end. We leave the pump on for 8 hours/day, and i have been wondering if we should have it on for longer? Recent CYA measurement has been radical, as high as 180. I cannot drain the pool--city rules. I let the water level go down on its own by slightly more than a foot and then refilled with hose water. The CYA remains about the same, 178. In the meantime, post-SLAM and post water rise, i have found that the pH has descended to slightly above 7.0. Before the SLAM and the water lowering/raising, the pH was 8.2. This is wild. I accept anyone's advice, and please do not tell me that i am merely inept at caring for my pool? Thank you all.
