High winds can blow organics into the pool. The more organics the more the FC is consumed. So to answer your question. Wind doesn't affect the OCLT, the material blowing with the wind affects your OCLT.
Yes, that is what I meant. The material blowing. But, I am still to continue SLAM correct?High winds can blow organics into the pool. The more organics the more the FC is consumed. So to answer your question. Wind doesn't affect the OCLT, the material blowing with the wind affects your OCLT.
You went from 22.5 last night to 22.0. If those are correct, you passed the OCLT!My pool water didn’t pass the overnight test. Lost about 3 ppm.We have had really bad winds, can winds affect the OCLT?
I didn’t add any LC yesterday, as I am trying to lower the FC to 20 ppm.
FC as of 4:50 am was 22 (last night FC22.5)
I’m going to run the SWCG, I’m thinking of setting at 60% for the day. I am already super on the 0871 liquid agentWhere do I get refills on that? I have plenty of powder agent.
Going to be scrubbing more due to the winds and the dirt that is landing in pool due to winds.
picture attached was from last night. i was amazed on how clean the water looked.
I had a severe migraine so I couldn’t do a lot of scrubbingyesterday
Not that I can see. I can visibly see dirt residual on the tanning bed area but it can be easily brushed into pool for vacuuming.Are you getting any debris build up in the pool, ie dead algae?
Can you send me the link to smart stir?Also, (apologies that I forgot 10 pages deep), are you using a smart stir to test ? it helps the accuracy greatly.
Besides that, there is tons of human error in play as well. You couldn’t hit 40 basketball free throws in a row anymore than you could make 40+ perfect drops.
Either one or both of these could easily explain the OCLT. Add in some organics being blown in by the wind and you might be sitting pretty.
I’d continue letting it drift down and see if it holds at a more reasonable 8 FC. That way you only have to make 16 perfectly repeatable drops. You won’t lose ground if the SLAM isn’t over, it will just be a slight pause / slowing in the killing action.
Link to smart stir please? Is there a specific one?Also, (apologies that I forgot 10 pages deep), are you using a smart stir to test ? it helps the accuracy greatly.
TFP sparkly! Welcome to the forum!Wow! I just saw some crystal clear pools!!! Never has my pool been that clear In the 8 years I’ve been having it serviced.
I use a long 1/2 in pvc pipe to draw water out of my pool. Never need to stick my arm in it. (But my water does not irritate my skin either so I don't need the pipe. I just use it so my arm doesn't get wet LOL).....Also, my arm is not irritated or itchy or dry or anything from getting water from the pool to test the water.
Well for the 8 years of having serviced twice a week. I would always be itchy in our water and even after. Eyes would get irritated or be super red after. I just always assumed that was normal since that is what I was told by our service people.I use a long 1/2 in pvc pipe to draw water out of my pool. Never need to stick my arm in it. (But my water does not irritate my skin either so I don't need the pipe. I just use it so my arm doesn't get wet LOL)
Ok. Thank you. I linked my Amazon to TFP for future purchases.You can order this off of Amazon and maybe have it in a day or so. This is what I purchased. See link
Taylor Technologies 9265 SpeedStir Magnetic Stirrer Start-Up Pack with Stir Bar and Batteries: Swimming Pool Liquid Test Kits: Amazon.com: Industrial & Scientific
Taylor Technologies 9265 SpeedStir Magnetic Stirrer Start-Up Pack with Stir Bar and Batteries: Swimming Pool Liquid Test Kits: Amazon.com: Industrial & Scientificsmile.amazon.com
Ok. Throw out everything you knew or felt. Like what *used* to be considered clear water, or what was properly treating the poolWell for the 8 years of having serviced twice a week. I would always be itchy in our water and even after. Eyes would get irritated or be super red after. I just always assumed that was normal since that is what I was told by our service people
Yep! It’s getting easier to unlearn the little I did know about pools. Never in my mind did I ever think I would take on that responsibility. I had even bought Chlorine Neutralizer (before finding TFP to lower the FC because at 5-6ppm I was told it was too highOk. Throw out everything you knew or felt. Like what *used* to be considered clear water, or what was properly treating the pool
You’re here now and it’s going to redefine every aspect of your pool ownership.
The only thing any of us regret is not finding this place sooner.
That is not good. Swimming should be a pleasant experience. You will get there.I would always be itchy in our water and even after. Eyes would get irritated or be super red after.
