I'm hoping someone has an idea here while I wait for a chance to contact Tech support.
I purchased a Pentair Warrior SE from Marina pools on 3/18/21. Last night I noticed the cleaner was not functioning properly. I press the power button, the water pump kicks on, the blue LED on the front flashes, the cleaner moves 3 steps back, 2 steps forward, an then the rollers turn off, the blue LED keeps flashing and the water pump stays on for a few more seconds, then all functions turn off. The controller still is lit as normal.
Troubleshooting:
So far I have cleaned the entire robot, basket, filters, check rollers for obstruction. Unplugged for over night and power on again in the morning with same results. Moved to another area of the pool and powered on again. Just for troubleshooting purposes I tested another outlet with same results.
Up until last night, the robot has worked flawlessly.
All suggestions are welcomed.
Troubleshooting:
