6/MO Pentair Warrior SE Not working
joshscott84
Active member
Apr 21, 2020
43
Tampa Bay
I'm hoping someone has an idea here while I wait for a chance to contact Tech support.
I purchased a Pentair Warrior SE from Marina pools on 3/18/21. Last night I noticed the cleaner was not functioning properly. I press the power button, the water pump kicks on, the blue LED on the front flashes, the cleaner moves 3 steps back, 2 steps forward, an then the rollers turn off, the blue LED keeps flashing and the water pump stays on for a few more seconds, then all functions turn off. The controller still is lit as normal.
Troubleshooting:
So far I have cleaned the entire robot, basket, filters, check rollers for obstruction. Unplugged for over night and power on again in the morning with same results. Moved to another area of the pool and powered on again. Just for troubleshooting purposes I tested another outlet with same results.
Up until last night, the robot has worked flawlessly.
All suggestions are welcomed.
mknauss
51,246
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Might be hair or other items around the pump impeller. Others have seen that as an issue.
Did you contact Marina or Maytronics?
Jimrahbe
27,598
Bedford, TX
Josh,
When the robot starts up, it goes through a self-test.. That is what the move forward and back is doing and then it does a test of the suction motor.. You should see a little surface water eruption right above the robot.. If it quits, after the self-test, the robot thinks something is wrong..
I too suspect that your suction motor has a clogged impeller.. You can't see it unless you use a screwdriver and take some "plastic" out of the way.. The manual describes exactly what you need to do.
SunnyP2000
295
Long Island, NY
Hayward Aqua Rite Pro (T-15)
Just checked quickly and the impeller turns freely. No hair nor any other obstructions. Robot is spotless clean. Waiting for an opportunity to call support as I have a conference call shortly.
did you try this .link to video
I bought my warrior in march as well and i had the same issue last week. tried everything finally was able to get hold of someone in marina and sent it back last week for repair. i believe they just received it yesterday . lets see what they say.
GregInClaremont
153
Claremont, CA
I have a dolphin s300i that's very similar in design to yours. I just did some motor brushes on the impeller motor and I goofed up with the o ring when reassembling the motor case assembly.
Mine did this same thing you're describing and after opening it I up again I realized water got into the motor box where the circuit board is. I let it air dry over night and I'm using cotton swabs and alcohol to clean the board up but not looking good.
I hope your nearly new unit doesn't have a water leak that may have caused this...
SunnyP2000
295
Long Island, NY
called marina today for update, they said motor is bad and they are waiting on new motor which should be here in a day or so. they install new motor and test, i am hoping its getting shipped out soon. leaves are falling like crazy and this when i need that darn robot more than ever. I am lucky to borrow my neighbors while I wait. good luck with yours i am assuming its the same issue.
joshscott84
Active member
Apr 21, 2020
43
Tampa Bay
I just sent an email asking for an update. If I don't hear back I'll give a call tomorrow at noon. I suspect ours came from the same lot. I did not the manufacture date on mine was just over 2 years from the purchase date. May or may not have mattered but just pointing it out.
Newdude
18,156
NY
Many things only come out with new models every 5 years or so. Yard equipment for example. They sit at a dealer sometimes for several years. The purchase date starts the warranty and they shoud last X amount of time from then once they are put into use.
joshscott84
Active member
Apr 21, 2020
43
Tampa Bay
Yes but in that time orings and gaskets are deteriorating. Capacitors can pop and transistors can swell. I am an IT engineer and have seen the far ends of both spectrums. Fact is the unit died in under 6 months with less than 20 uses. What's more troubling is Sunny purchased his same model, from the same dealer, within the same 7 days of my purchase and his unit died within 7 days of mine as well. Speaks for its self but take it for whatever it is worth
joshscott84
Active member
Apr 21, 2020
43
Tampa Bay
Should have it back Thursday
"Hi Josh,
Your cleaner is all fixed and we had it running in the pool the last couple days and it's working great. The problem was the servo motor was seizing up. We replaced the whole motor assembly and that solved the problem.
Thank You,
Margaret Mills"
SunnyP2000
295
Long Island, NY
"Hi Josh,
Thank You,
Margaret Mills"
that's exactly what they told me, so it must be bad batch of motors. I wondered if they replaced it with new motor or refurbished motor ? i never asked.
