- Nov 7, 2012
- 81
Thanks! I have a Clean and Clear 420 and I cleaned the cartridges yesterday and ran it for 2 hours, but I will shut it down for the weekend.
I'd hold off draining that much water until I had my own test results. You could be at 150. You could also be much higher. When I took over my pool care, my CYA was in the 220-240 range!MonsterPoolMan said:Thanks guys! I found the other one on the net for around $50. I am going to drain 3/4 of my water this weekend. I love this site! 1st problem I had in years and I thought I was doing the right thing all the time! I will keep you updated.
One thing I found, for double the price of renting a submersible pump, I am just going to purchase one for under $90.
One more question, I never used liquid bleach or chlorine, how often do you have to put that stuff in once your balanced? Should I purchase a whole bunch like I did when I used pucks?
dmanb2b said:Draining the pool fully is not advised, we actually do not advise draining more than 6"-1ft at a time, but if your water table is low, you should be OK. You can start re-filling. I would just inspect the cartridges, but replacing them won't hurt.
jblizzle said:If you keep track of how much powder or pucks you use, they are fine.
Although it is simpler to just as the stabilizer and chlorine separately.
Posted from my Droid with Tapatalk ... sorry if my response is short
jblizzle said:The easiest would be to get pure stabilizer either from Leslies or Walmart. And then use bleach to add chlorine.
But for reference:
The Power Powder Plus is Cal-hypo, so it adds calcium, NOT stabilizer
The Chlor Brite is Dichlor so it will add CYA and what you may want to use.
Fresh N Clear is a non-chlorine product ... not what you should use.
MonsterPoolMan said:dmanb2b said:Draining the pool fully is not advised, we actually do not advise draining more than 6"-1ft at a time, but if your water table is low, you should be OK. You can start re-filling. I would just inspect the cartridges, but replacing them won't hurt.
Water table??? Bands are broke on 2 cartridges. They used to be blue on the rubber part but now are green. I was curious, why only 6 feet?
MonsterPoolMan said:jblizzle said:The easiest would be to get pure stabilizer either from Leslies or Walmart. And then use bleach to add chlorine.
But for reference:
What is Fresh and Clear? They tried to sell me that before and I was like *** if it isn't chlorine, why buy it?
But for reference:
MonsterPoolMan said:Thanks! I went ahead and did a 3/4 drain. I used a sample of the remaining water, and topped it off with tap water and CYA looked to be at 50. I am rolling the dice now and filling it up! Should be about 3 days. I might need Diholar now. I am concerned about high PH because the same test gave me 7.8. I will post numbers when filled and post them. Hopefully it just "bleach away"!
