- Jul 21, 2013
- 65,449
- Plaster
- Pentair Intellichlor IC-60
Do we on TFP suggest Salt water generators? (I need to read up on Salt vs Chlorine, haven't had SWG).
Yes, read...
How to Chlorinate Your Pool
Before chlorinating your pool, you should know these simple tips. Learn the best way to add chlorine to your pool.
Salt Water Chlorine Generators
Salt Water Generators are designed to produce small amounts of chlorine continuously. This is perfect for day to day use and reduces work for the homeowner.
What is the overflow drain, just from too much rain, etc? Is that not standard?
Do not assume anything is "standard". There are no standards and pool builders do their own thing.
Without an overflow drain in a big rain storm the pool water level can rise above the coping and spill out. You will have to pump out water to lower the pool water level. If you get an overflow drain make sure the PB understand how to install it so it only drains water when it approaches the top of the skimmer mouth. We see overflow drains placed too low and interfere with normal skimmer operation.
Here is one example of an improperly installed overflow drain...
Top Drain - Overflow blocking device
Has anyone used this or similiar items to block the overflow and keep water from going out when you go swimming? We used our pool for the first time and don't like the idea of loosing the water for no reason. https://www.texaspooltechs.com/top-drain/ Top Drain
Thanks for the advice on Jandy, I only know Hayward, so sound like I should go with Pentair, not Jandy.
Hayward falls someplace between Pentair and Jandy in my opinion. They each have good products and bad ones.
