Thread: What effect does heating the pool have on chemicals
    Central Connecticut
    159
    I have a Jandy Heatpump that does a great job. Pool is at 73 degrees, will heat to about 85 degrees.
    Does anyone know what effect the heated temperature of the water has on the chemical levels?
    18x36 IG 26,000 gal, Vinyl Liner, 24" Sand filter Hayward S224T, Jandy AE3000 heatpump and 1.5 HP SuperPump. Circupool RJ45 SWG
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: What effect does heating the pool have on chemicals
    Nothing significant, but chlorine demand will increase a little with higher water temperature. Better start that heat pump now if you want it to be 85 by the weekend!
