OmniLogic and Heat Pump show different temperatures
browerjs
Active member
Oct 30, 2019
43
Beavercreek, OH
My Hayward Heatpump shows a temperature about 7 degrees lower than what the OmniLogic app/pad show. When I measure the actual water temp, it falls right in between the two.
Does anyone know what might be going on? Omni controls the heat pump just fine.
Test the temperature sensors using an ohmmeter.
If the sensor is reading the temperature wrong then replace the sensor.
