Hi,
Pool Size = 15,000 gallons, salt water, Spa with spillover to pool
Current setup = Jandy Truclear Pro Series Salt System, Jandy Cartridge Filter, 2 Jandy Single Speed Pumps (1.25HP for Pool, 2.25HP for Spa), Aqualink System
I'm replacing my old gas heater for an Electric Heat Pump. While I'm updating my heater, I thought it would be a good idea to update the equipment. I've had a few pool companies out and they are all recommending different setups.
Questions:
1. Should I re-plumb my entire setup (PVC, Valves, etc.) and go from two pumps to one 2.7HP Jandy VS Speed Pump? Or keep the plumbing as is and upgrade the two pumps to two VS speed pumps (2.7 THP Jandy FloPro pump for the spa and another 1.65 THP Flopro for the pool)? Is there a benefit to have a 2 pump system?
2. Filter - I keep reading that bigger is better but all the pool companies are recommending a CS200 or Hayward 1750. I've read that it would be better to go with a 300+ sq/ft filter cartridge system to improve the flow of the pool and it would also allow me to go longer in-between cleanings
I dont' have any other water features beside the spill over and one small jet on the sundeck.
Please help!
Questions:
Please help!
