1st Pool Build - Freeport, TX
textommyboy
128
Pearland/Freeport, TX
Finally some progress today. The cement crew came out and poured the cement decking around the pool. Next up is either Sundek or plaster (whichever the PB can schedule soonest)!
Pool decking that connects the pool area to the cement patio under the house.
3' perimeter decking around the pool.
And last, but not least, the old flower bed under the house that we got tired of pulling weeds out of every weekend!
textommyboy
128
Another update for today. Sundek in Tweed Grey was applied to the decking and coping around the pool.
Next up is Wet Edge Deep Sea Blue plaster tomorrow and then acid wash Thursday. Water immediately after the acid wash and jumping in Friday!! Finally a light at the end of the tunnel...
kimkats
46,763
Tallahassee, FL
SO CLOSE!!!
Make sure someone is there to check the plaster color! We had a couple of builders that got the wrong color/grade! One had to be chipped out to redo! The other caught it before the bags left the truck so it was easy to fix.
Kim
textommyboy
128
Plaster crew came out today and finished the job in a little more than three hours. PB project manager confirmed plaster is Wet Edge Prism Matrix in Deep Sea Blue. Here's the pics from today.
Tomorrow they acid wash and start filling the pool. Equipment startup is Friday and depending on how quickly the pool fills up pool school could also be Friday.
The PB said we could jump right in as the pool fills up with water. He also said we don't have to brush this plaster but it couldn't hurt for the first week.
The light at the end of the tunnel is getting much brighter now!
kimkats
46,763
Tallahassee, FL
It is REAL! You have a pool! Oh Happy day!
I am going shoot you a link. Please know that you have to do what your PB says as he holds the warranty card but............this may help guide you.
Pool School - Start-up New Plaster
Your PH will be wild at the beginning as the plaster cures. Be ready for it with LOTS of muratic acid.
Do you have a good test kit yet? If not look in my siggy for the ones we use and love.
kim
textommyboy
128
Thanks kimkats! We are very excited to jump in once the pool gets to a level where we can jump in without breaking any bones. We're hoping after the acid wash that the water will look as nice as spool's pool since we have the same plaster.
We already have a Taylor Technologies K-2006 Pool Test Kit we purchased in August that we'll have to learn to use. Our PB also gave us a small Pentair test kit that we'll keep as a back up. We'll definitely keep your kits in mind if we ever need a replacement.
kimkats
46,763
Tallahassee, FL
I also have the Tayor K2006. It fits the space I had purrfect. I just order refills from TFP when I need them.
I am glad you already have a kit. There are videos showing how to do the test. Go ahead and test everything except the CYA so you will know what you need to buy. Post the results here.
Kim
textommyboy
128
Plaster was acid washed this morning and filling up pool now! We're using two hoses to fill it up. The PB said we didn't need to use the empty container/float trick but did recommend covering the ends of the water hoses with an old sock or in our case a cut up t-shirt to keep the plaster from getting scratched. Midnight swim anyone?
Equipment startup tomorrow and maybe pool school too. Hopefully it won't be too cold tonight to jump in!
textommyboy
128
Well the day has finally arrived! The pool filled up by 1am Friday morning. Later that morning PB dropped off the two ledge loungers, net, brush, pole and some chemicals. He also showed us how to carefully load up the chlorine pucks and started up the equipment. Equipment guy came out in the afternoon and labeled the valves and gave us some initial pointers about the equipment. He added muriatic acid and shock to the pool and will be back next Saturday for pool school.
Friday's pics...
View of the pool (excuse the yard - it's still under construction) from the upstairs deck. Chemicals were added and water pump/filter going full speed!
Water at 5' (middle of the pool).
View from the tanning ledge toward the end of the day. Water's starting to clear up.
View of the water at the tanning ledge and steps. Tanning ledge has about 6" of water.
One of the bubblers on the tanning ledge.
Saturday's pics...
View from the tanning ledge. Water cleared up nicely overnight.
Another tanning ledge and steps shot.
View of the water mid-morning.
View of the water in full sunlight.
So now the wait begins for final clean up and sod for the yard!
ummgood
1,095
Austin, TX
It looks so awesome! Congrats.
Where did you get the chaise on your tanning ledge? My wife wants something like that and I might buy her one for christmas.
Oh wow I see your PB dropped them off. I wonder what brand they are?
textommyboy
128
Thanks we are really enjoying the pool! The chaises are actually called Ledge Loungers (In-Water Pool Furniture | Ledge Lounger) and were part of the deal with the PB. Ordering them direct is very expensive so you may want to see if your PB can get you a better deal.
We originally wanted white but didn't want to wait until next week so we went with "granite gray" Ledge Loungers. They are made from thick plastic and fill up with water from the pool to weigh them down. They're very comfortable with the mid (butt/lower back) and foot sections underwater. Unfortunately I'm only 5'7" so my feet don't make it in the water over the knee hump so I just lay them out on the side of that hump.
ummgood
1,095
Austin, TX
Wow those are great but way more than I was anticipating. I'll have to keep an eye on them as a wish list item. My wife is 5'0" and I am 6'4" so we will have different experiences with them for sure.
