- Mar 8, 2022
- 324
- Vinyl
- Pentair Intellichlor IC-40
Excavation for the paver pool deck starts today. They think it'll only take a day or two, and then they'll be putting down and compacting the modified 2A base material. Once that's done I think I need to get my bonding finished because the next step is the coping and I'll no longer have access to the steel walls to attach bonding wire. So, planning out my next steps:
- paver deck excavation
- put down compacted paver base
- install with cement step and ladder anchor cups
- finish running bond wire around pool, bonding to anchors and steel wall
- install paver coping
- install paver pool deck
- finish grade and topsoil around pool site
Still a lot of work to do, but it's nice to be able to at least see the finish line.
On the pool chemistry front, I did another full test recently. I'm not sure if I read it differently this time, or if it actually increased but my pH is up to 8.2 now. Maybe the high TA contributed to that rising, but either way I'm going to go pick up some MA and try to drop it down to 7.2
