Results 1 to 7 of 7
Thread: pH 7.0-7.2
    Nov 2016
    Melbourne, FL
    139
    pH 7.0-7.2
    OK, so I had a pH of 7.8+. So I added MA yesterday, and may have had a bit of a heavy hand, and my pH went down to almost 7.0. Should I raise the pH chemically, or just allow it to creep up. Right now I am adding 1 cup of MA twice a week. Any thoughts on TA, maybe I should use this chance to bring the TA up a bit?
    Thanks!
    FC: 3.0
    CC: 0.0
    pH: 7.0
    TA: 75
    CH: 300
    CYA: 70
    NaCl: 3400
    15K Gal Gunite Pool, White Pebble Surface (unkown), Pentair Intelliflo Variable Speed Pump, SunTouch automation, sta-rite plm100 filter, Hayward AquaRite AQR-15 SWG.
    Pyrodav's Avatar
    Dec 2016
    Chillicothe/ohio
    175
    Re: pH 7.0-7.2
    Aeration will help by turning your jets up for a while if you don't wanna chemically dose. Your salt cell should bring it up pretty quick also.
    7000k Viking fiberglass Bermuda, Sand filter w/glass, Pentair SuperfloVS, Pentair IC20 swg
    Raypak 106k, Dolphin s-200, Taylor k-2006c, Taylor k-1766, Speedstir, Little Giant cover pump.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Re: pH 7.0-7.2
    If you added the MA yesterday, the pH is probably up to 7.2 or higher already. In the future, target a slightly higher pH when calculating the dose. If you still overshoot, it might be that your pool isn't as big as you think. Happens a lot. Builders tend to overstate things.
    TA is fine where it is. You ought to consider raising the SWG% or the pump run time to get the FC up a bit. You're right at minimum.
    Nov 2016
    Melbourne, FL
    139
    Re: pH 7.0-7.2
    Thanks Richard, I'm targeting an FC of 4.0, but with all of the clear sunny days we've been having here I should have raised my SWCG%, was 40 now 50%. I am in a Wednesday and Sunday testing routine since my PebbleSheen finish was completed in November. Due to drama at work, I missed my Wednesday test and by the time Sunday came around I had a pH of at least 7.9 (definitely over 7.8). Usually I shoot for a pH of 7.6 where I let it rise to 7.8 and knock it down to 7.4 with MA. I'm hoping that my MA use goes down as the surface cures more completely, but with the SWCG I guess I'll be adding MA weekly.
    Apr 2016
    Riverview, FL
    351
    Re: pH 7.0-7.2
    I'm in Florida too. My pool was completed last July and included SWG. My pH rises every test (same schedule as you). I find that I have to add 12oz MA every time.
    You might want to adjust your test targets to be more kind towards higher pH without scaling until your pool pH relaxes it's MA needs.
    Free Form 13K IG (Quartz) w/Screen Enclosure - 2 Sheer Descents, 1 Bubbler - Hayward 60 SF DE Sta-Rite - Hayward SP3400VSP EcoStar - Hayward Aqua Rite AQR9 (T-Cell-9) SWG - Zodiac MX6 - July 2016 - Taylor K-2006 - Taylor K-1766 Salt Test
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,310
    Re: pH 7.0-7.2
    PP,
    I would suggest that you don't "knock it down" until it gets above 7.8... 7.8 is in range and I find that my pool will stay at 7.8 for weeks before moving higher. When I try to keep the pH lower than 7.8, it will quickly move back to 7.8.
    Apr 2016
    Riverview, FL
    351
    Re: pH 7.0-7.2
    Quote Originally Posted by Jimrahbe View Post
    PP,
    I wish I had that option, but after being away for 3 weeks I found my pH just continues to climb (pump running at relatively low RPM of 1250 and no aeration features). My pH climbed to 9.0 after three weeks, so it never found a point of settling in. I'm unsure why some people have better luck with stable pH and others, like me and the OP, don't.
