Thread: Intermatic Pool Timer - Where is the model number?
    JodieM's Avatar
    Jul 2013
    Brownsburg, IN
    152
    I need to replace the timer, where do I find the model number?
    Pool Built June 2018,
    16x32, 20K, IG vinyl,
    2 speed Jandy Pro Plus Pump, Jandy JS Sand Filter, Jandy Tru-Clear SWG,
    JANDY JXI POOL HEATER/260K BTU, Polaris 280 + Booster, TF 100 Test Kit
    JodieM's Avatar
    Jul 2013
    Brownsburg, IN
    152
    Re: Intermatic Pool Timer - Where is the model number?
    If it helps, the double pole breaker has 2 30 amp breakers. The single pole is for the patio lighting.
    Feb 2015
    Chandler AZ
    1,061
    It looks to be a T104M.
    What's wrong with it?
    Is there a label on the inside of the timer panel door with a model number on it?
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    JodieM's Avatar
    Jul 2013
    Brownsburg, IN
    152
    The timer doesn't work anymore, the inside gears aren't turning.
    I looked everywhere for a label and found nothing. I ended up ordering a T104M.
    Feb 2015
    Chandler AZ
    1,061
    Sometimes it's just the timer motor. Those are replaceable too. But since you already ordered a complete timer, you should be all set.
    Just be sure to wire it exactly as your present one - I believe it's set up to only allow your booster pump (on the timer on the left) to come on if the pool pump (timer you are replacing) is on.
    Let us know how it works out.
    Gene
