T104M that someone wired with household Romex.
Remove the mechanism from the "indoor only" box and put it in the box outside. You only needed that mechanism. The small tab at the top of the mechanism will push up, releasing it from the mount.I got a new one and am all set to install it when I notice the label says "Type 1 Indoor Use Only". I was going to replace the old one which is installed on an exterior wall next to the pool pump. Did I get the wrong one?View attachment 519689
I did. It is 240 volts.Did you measure the input voltage to verify that it is 240?
