Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: I was never OCD until I had a pool...
    Cocoswims's Avatar
    Feb 2017
    Little Elm, TX
    32
    I'm out with a flashlight watching my pool fill, infinitesimally, in the middle of the night. I have city water. Should I add another hose to the other bib and throw it in? Anything to be gained there? Aside from my own satisfaction of feeling that I 'did all I could'?
    28.5k gal,112' perimeter, 600 sqft, 8.5', recreational pool/spa, Pentair FNS 60 DE filter, Pentair Intelliflo 3.0 hp var speed pump, Pentair Master Temp 400k BTU. Blue Surf Pebble Sheen, Travertine Coping and Decking,
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,917
    Re: I was never OCD until I had a pool...
    Well good morning to you! It is like watching a pot to see it boil. It will happen in time LOL.
    I am not sure where you are (please put your state in your location) so this may not help you any but yes adding another hose will help spend up the filling process.
    Is this a new pool?
    Kim
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    571
    When I initially filled my pool I used 3 hoses on 3 separate outdoor spigots. Our have mandatory backflow protection, so they somewhat restrict flow, so adding another hose to same spigot would not really help. 2 was a lot better, the third helped some more, but not as much as between them they used a lot of house's capability.
    38'x16' Fiberglass pool - 3.5' - 8' deep - 19,000 gallons. AutoPilot Total Control SWG (RC-52 cell), Pentair SuperFlo VS, Pentair SD70 Sand Filter, Coverstar Automatic Cover, 10' board, PAL Treo lighting, Polaris 9550 Sport robot, Lamotte ColorQ Pro 7 test kit.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Put in two, it will help. Even if it doesn't actually double, it will cut your anxiety by more than 1/2. Cut down on the crazy all you can.
    Essential Links:
    rajung's Avatar
    Mar 2015
    Iowa
    255
    a 3rd hose will definitely help.
    Just have to make sure it is hooked up to a neighbors faucet.
    aside from that, I remember running a bunch of hoses from my house over night and the next morning couldn't figure out why I had low water pressure throughout the house after the pool was filled.
    After looking at all the wrong places first, I realized I plugged up the whole house filter I installed,doesnt take much sediment when you have the best filter, good and bad on those things.Some day might eliminate from outdoor taps.
    Doughboy AG 16' x 32' oval, 13,700 gal.
    AquaView by Doughboy 150lb sand filter model 0-1709-20
    PowerLine pump by Doughboy model 0-3047-200, 1.5hp-single speed-20amp
    Gulfstream electric heater-HE125-R-A
    Taylor K-2006 test kit
    Jul 2015
    Central Valley CA
    1,166
    We used 2 hoses and once the shallow end got wet used a tape measure and checked the level twice 30 min apart to gauge the fill rate and set a timer based on when the math said we would be with in an hour of being full. Worked like a charm.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Cocoswims's Avatar
    Feb 2017
    Little Elm, TX
    32
    Quote Originally Posted by kimkats View Post
    Is this a new pool?
    Kim
    Hi kimkats, sorry, we're in TX, Noth Dallas suburbs and yes, it is a new pool. My parents always had pools when I was growing up but, this is my first build so, it's really exciting for me! My husband, the mind reader, added another hose this morning and the pace seems to have picked up. Thanks!
    Cocoswims's Avatar
    Feb 2017
    Little Elm, TX
    32
    Quote Originally Posted by Patrick_B View Post
    Truth! Thanks, Patrick!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Yup! Good luck on the fill, and let us know how much water you get from the neighbors hose.
    Essential Links:
    Cocoswims's Avatar
    Feb 2017
    Little Elm, TX
    32
    Lol, I decided against asking him since when we offered him $500 to take down 2 sections of his fence for 8 hours to dig, and to ALSO to additionally, replace any and all damaged grass with new sod and ALSO to additionally, replace any damaged sprinkler heads, he countered back at $750 and a 10 page contract.
    I'd rather fill the pool with an eyedropper than ask him for anything else.
    triptyx's Avatar
    Apr 2016
    1,476
    Yuck, I hate neighbors like that. :P
    If you wouldn't mind adding ", TX" to your location please, that would help folks that aren't familiar with the Dallas Metroplex target their advice to your area.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Cocoswims's Avatar
    Feb 2017
    Little Elm, TX
    32
    Thank you, Triptyx, I will do that. Please forgive my newbie-ness, this is the first forum I've ever joined, in the history of 'The Internets'. TFP was too excellent a source of information
    to let me stay in my non-forum comfort zone! If you see me make any other faux pas, please bring them to my attention. I don't want to embarrass myself more than usual.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Quote Originally Posted by Cocoswims View Post
    LOL!!! Welcome to TFP!
    TFP was the first forum I ever joined too! And look what happened!
    triptyx's Avatar
    Apr 2016
    1,476
    Nothing to worry about, you're doing great! Thanks for getting that added.
    To be honest, on most forums I don't put a location at all, but for this one your location is pretty important when you're getting advice.
    Cocoswims's Avatar
    Feb 2017
    Little Elm, TX
    32
    Wow! That's awesome! I don't ever think I could ever end up as a moderator, I'm struggling enough with the chemicals thread. Still, I AM OBSESSED with my first pool so...you never know! Where in DFW are you, pooldv?
    DFW, TX
    24,974
    It is definitely a lot at first, I was overwhelmed too. Just keep reading, testing and tweaking and you'll be there in no time.
    I'm out in the boonies, away from all those folks! Like you. I'm out by Lake Lavon in the woods! There are pics in the link in my sig.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,265
    Coco,
    I'm pretty sure that OCD was one of the things I paid extra for in my pool contract. Boy, I sure got my money's worth...
    Thanks for posting,
    Jul 2012
    Tallahassee, FL
    33,917
    This is a fun thread! All kinds of fun!
    Kim
    Cocoswims's Avatar
    Feb 2017
    Little Elm, TX
    32
    Kim
  20. Back To Top    #20
    Dec 2015
    Hawera, Taranaki, New Zealand
    443
    Hi Coco, love your name
    I'm afraid to say it sounds like you are well on the way to having a full blown case of sparklipoolitis
    A lot of us here suffer from the condition and there is no known cure I am afraid
    I see you have already met a few of our regular friendly support group
    The support group and a good test kit are essential to keeping your condition under control
    6000 gal, AG vinyl, Intex ultra frame 16ft, 1200 Gallon Sand Filter, DIY Solar, Clear Choice Labs Testing Kit
