- May 23, 2015
- 24,490
- Plaster
- Pentair Intellichlor IC-60
As others have stated, the BioGuard Inhibit is polyquat-60. It is an algaecide and one of the few algaecides TFP would ever recommend using. However, we do not recommend using it on a regular basis but only during certain treatments (such as ascorbic acid treatments for metal stain removal). Some people do use it when they winterize their pools but being in Dallas, I'm not sure if you close your pool or not? Don't get rid of it because it is stable (keep it indoors) and it is generally more expensive than other kinds of algaecide which are less effective.
The scale inhibitor is only needed if you have a scale or metal problem? Do you have well water filling this pool or municipal water? Did you ever have metal stain problems in the past? It contains a chemical compound called HEDP which is mainly used to control both calcium and metal scale. It's not something one would regularly use and it is safe to store if you want to keep it.
And finally the ph-Up is just sodium carbonate which would be useless in a pool like yours (you'll most likely be looking to lower pH not raise it). However, it is just pure washing soda and so you don't have to throw it away. Add 1/4-1/2 cup with every wash cycle and it works as a laundry detergent booster. Soda ash, or washing soda, is also used as a dye mordant when tie-dying white tee shirts. Arm & Hammer sells it as a laundry product in some of the big box stores like Walmart. There's nothing special about it being branded for pool use it's literally all the same chemical.
