BattleOfYakima
I just want to say you're doing great. You're learning really fast and you're doing the absolute best thing in asking any and all questions, no matter what. Your pool is lucky to have you!
Yes, keep it up, and you will get there.![]()
There are two main reasons to keep the TA in the 60-80 range for pools that have SWG's.Lee, the water looks good and thank you for checking in!
Kim, thank you for the pH and TA lesson!
Ping, I ran some tests just for you!
The pH is currently 7.8. Looks like I need to add acid more on that later...
FC is 3 (I'll be adding a jug of bleach today).
TA has climbed back up to 90, more on that later...
The SWG says the level of salt is 2.4, but the K-1766 test says it is 3000. I am not sure why the large discrepancy unless it's because the salt cell isn't working right?
For the acid and TA, PoolMath says: To lower TA you reduce pH to 7.0-7.2 with acid and then aerate to increase pH.
So, since TA has climbed back up, should I try the tip above by lowering pH to 7.0-7.2 with acid and aerate to increase pH? I was thinking of aiming for 7.2. What do you think?
Leave the SWG on at 100% until you get back.
Add just over a cup of acid now to lower the pH to 7.5 and see if it measures 7.5 about an hour after you add the acid.
Before you leave add enough acid to bring the pH back to 7.5 if it rises before you leave.
The night before you leave add enough bleach to raise the FC to SLAM level which is 24ppm for your CYA level. Leave the pool covered while you are away. Hopefully you return to a clear pool.
Do you have enough time to do an Overnight FC Loss Test? Read this link and let me know if you can do this now.
I don't like how much chlorine the pool seems to be using right now with it still being cool and covered hence the reason for the above test.
The Target for CSI just means that the numbers you have entered in the target column are going to result in something that is more acidic and hard on plaster than is recommended.
So, let's talk about that for a moment. What are your target numbers set to in PoolMath?
Concentrated Bleach, as long as it is unscented and not "splashless" is perfectly fine to use. The only difference from "liquid chlorinate" is that the concentrated bleach isn't as strong. Even if there was scent or splashless formula, it just makes things sudsy for a while - it's not a big deal.
You're doing great, mama!
I love the education you are getting from the great people here and I am learning right along with you, as mine is still a little confusing to me!
Blessings to you!
Since you're adding bleach, definitely go with the non-SWG numbers for now. What is your current water temperature so I can help you with that CSI?
