I'll highlight each question as blue text if you don't want to read all of this... thanks in advance for the help!
Background
Purchased a home at the end of August 2016. Now I'm the proud owner of a pool and hot tub... first time I've had to maintain either. It has been fun learning - but frustrating as well. The previous owner had a pool guy that came over weekly - cleaned the pool and added chemicals. I allowed the pool guy to do his thing in Aug and Sept then fired him. I found this website, and decided that I could handle it, save some money, and probably have better water conditions.
Location is Central Alabama
Equipment
Pool:
Current Test Results
Temp = 52o
PH = 7.5
CH = 150-175
TA = 100
CYA = 100
Current Problems
I'll spare the issues with the spa - I already posted a question in another spot here (Older Spa Maintenance).
I waffled back and forth about winterizing or not and ended up deciding not to. I've questioned several other pool owners in the area and get a variety of answers... doesn't seem to be a good answer for this location. So I decided to keep it opened. Thought it would give me time to learn more about testing and chemicals during the non-swim season. I figured I would make sure that the pump was running any time we got close to freezing temps.
Well - the pool started leaking around the beginning of November. I drained the filter and lines before we left for Thanksgiving vacation because it was going to get under freezing here.
The CYA of the spa is too high... the pool guy used a lot of triclor tabs (and the chlorinator was always used). I realized it with my first test (was ~120 then). Needless to say, I have put no more tablets into the chlorinator.
Since the pool calculator told me to replace 67% of my water, I thought that I would just let it leak. I figured that it was coming from around the light seal since it just started when the water got cold (and we are no longer using it). My logic was that I would have an easy time finding and fixing the leak once the water level stopped dropping. The pool has bubblers at the steps that have plugs in them... the pool guy said that they started leaking last year so they just plugged them. The water had just gotten down to them... the light is about a foot or more lower on the opposite end.
So, the leak monitoring has been ongoing and going fine. Last night and today we got a heavy rain (2+ inches). I looked out of the window this afternoon at the pool and it looks to be slightly greenish. That's got me a little worried. I don't want to end up with a swamp by the end of the winter. This is the first time I've noticed it, so it could just be that the rain stirred up the pool a bit more. I've been scooping out leaves all fall thus far.
The previous owners left a box behind that is from Leslie's... All in 1 Winterizing kit. Inside of the kit is a bottle of algae clear and bags of Chlor Brite. Based on my Google searching today, I found that the Chlor Brite is commonly called Dichlor... and the Algae Control is commonly called Poly-Quat or POD
Shew - long enough explanation for you? That brings me to a bunch of questions...
Background
Equipment
Pool:
- 30k gallon IG pool - vinyl liner w/ steps
- Sand Filter - Sta-Rite model T-240BP-1
- Pump - marathon electric - C1245 (1 HP)
- Pentair Rainbow - model 320 chlorinator
- Polaris model 360
- TF100 tesk kit and speed stir
Temp = 52o
[*=1]how does temperature affect the test results?
[*=1]are any of the test results or recommended levels temp dependent?
PH = 7.5
CH = 150-175
TA = 100
CYA = 100
Current Problems
Is there something else that I should do with the clorinator - or just shut it off?
Should I continue to do this or is there a better way to find the leak?
[*=1]I don't think that I should use the Dichlor as it will just make the CYA go higher... correct?
[*=1]Should I add the Poly-Quat?
[*=1]Should I just go get the recommended amount of bleach from Costco and shock it?
[*=1]The PoolMath calculator says the recommended shock level is 39... I would need 1732 oz of 8.25% bleach (that's a lot!)
[*=1]The pump is drained, so I have no way to get a thorough mix of chemicals if I add them... is this OK?
[*=1]If no, the water level is below the skimmer... my pump has two suction side butterfly valves on it. I am assuming one is for the skimmer and the other is for the water inlet at the bottom of the deep end. Should I close the one for the skimmer and run the pump with only the bottom one open?
