Dialing it in at about 60% with my current pump timing (running about 7hr a day overnight). Seems to be holding a nice 4.5-5.5 in this crazy Texas heat.
It needs to be producing during the day, to hold a particular FC level.
You are producing (X amount of FC) overnight and it drifts down all day like a liquid chlorine pool would. It likely drifts less than a LC pool would due to the higher CYA level, but it is definitely drifting.
If you are testing 5 FC at the end of the day, before producing tonight's FC, then it will work until the first hiccup. If you lose SWG production for one night, you'll be starting the next day with 5 FC, which isn't enough to get through and remain above minimum. Losing one production cycle isn't common, but can easily happen one to three times a season. That's 1 to 3 chances to be gifted a swamp.
If you are testing 5 FC in the morning, you are losing 3 to 4 ppm during the day, but putting it back before you test tomorrow, fooling you into thinking you had a constant 5 FC when you actually spent time at/below minimum. This is having a daily chance to be gifted a swamp this season.
Only producing at night requires some extra thoughts, hopefully this gets you thinking in the right direction.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
