We have a pump supporting water fall feature and a rock slide. Would like to control from Pentair app possibility of running only slide, only waterfall, and both. Is this still not possible in 2024?
Nope. You can have any two out of the three settings.Would like to control from Pentair app possibility of running only slide, only waterfall, and both. Is this still not possible in 2024?
Pentair has been promising for a few years their IntelliValve will do that. Maybe someday it will.Ok so I can’t get a different actuator that I can adjust incrementally through the app?
Jim - for my own knowledge - would this require the individual valve/actuator be assigned to 2 different relays so you can select one or the other or both?Utah,
Pretty simple fix.. Remove the single 3-way valve/actuator you have now, and replace it with a 2-way valve/actuator on each of the two water feature pipes.. Then you can select either one, or both..
Thanks. Maybe the OP will post what was done and how it is working.Herman,
The OP has a Pool and Spa IntelliCenter, which comes with 4 valve drivers.. Intake, Return, Valve A and Valve B.
I 'assume' he is using Valve A or B for the current water feature valve, so that should leave the other one open.
For my solution to work, he would have to wire one of the new 2-way valves to A and the other new 2-way valve to B.
No relays are used to move a valve, you would just use feature circuits.
