We purchased a house with a pool in Houston TX and will be going through our first potential moderate deep freeze next week.
Could use some help to make sure everything is working correctly/prepped. First time owning a pool and up north where i am from everone winterizes them but not here.
Pool Circuit shows Freeze Protection On.
Background:
Last night freeze protection went on below 35 and was doing its job alternating every 15 minutes between pool and spa. When just the Spa portion came on however, Screenlogic showed the Heater on as well but the Heater never actually was fired up. Normally if I turn the spa mode on manually the heater also comes on. Also should I wrap the white exposed pvc?
Lastly, what do I do with the 3 feature pumps? I haven't used them in about 2 months and there doesnt seem to be water when i look in the pumps but there might be some in the lines. Do I drain them somehow, just leave them off or do I run them all during the freeze (add to freeze protection) and let that water flow and waterfall everywhere. Attached photo's of the features. One of my pool guys said to run them. None of them were in freeze protection modes so I doubt they were run last 2 freezes unless homeowners manually ran. Didn't know if running those pumps and having that water spill everywhere over the rocks could freeze and have them pop or cause issues
Photo's of all setting
Photos of pumps and water features
- Panel: Pentair EasyTouch 2 - 8
- Pumps : 4 x Pentair Whisperflo ( 1 pump for Pool and 1 each for three water features. Additional water to spa rock spillover, center rocks and water fall rocks/Spillover grotto.)
- Spa spills over rocks into pool
Background:
