I'm very thankful to have found this forum.
My pool:
-26,000 gallon 10’ diving pool
- In ground (pop up) cleaning system
- Water feature
- Large connected jacuuzi
- Heater
Current equipment
- 2hp dying pump connected to every pool system
- Hayward DE6020 filter
-Hayward Northstar 2 hp pump connected to jacuzzi jets
Return Manifold
-2” pipe for main pool return to pop ups
- 1” pipe to aerator and 1” to mystery line
-1.5” pipe to water feature
- 1.5” pipe to pool wall ports
Suction to Pump
-2” drain
-2” filter basket
-2” jacuzzi
Jacuzzi 2.5” pioe from Northstar pump to jets
Heater looks like 2.5” as well
See photos
My pool was green when we moved in. Pool guy said he knew the house and the previous owner never wanted to put in a new pump or filter and the current pump couldn't handle the entire system. The filter pressure has been over 32 at times.
I replaced the DE grids and flushed the return lines. I adjusted the valves to out more suction focussed on the pool. I've been able to get the pool water in great shape through weeks of winter cleanings and $100’s of dollars in chemicals. The pump has a terrible drag on start up and is about to die. I literally spent 1-2 hours daily brushing, vacuuming and cleaning the pool. It's time to have the pool system take some work off my hands.
I bought a 2.7 hp VS pump and 525sq ft filter I plan to instal when I have the plumbing figured out.
-Would it be a benefit to the system for me to run 2.5” pipe into the pump, pump to filter, and filter to return manifold?
- is it worth it to increase all exposed plumbing to a half size bigger?
- Would it be beneficial to insert a flow meter or vacuum and pressure gages…or both? Is the juice worth the squeeze for the cost?
Between the conflicting information I've received from 2 pool professionals I've decided to research for myself. The first look guy told me new filter, 2.5 hp pump and bypass the heater. The second guy said 3hp pump and never bypass the heater.
I'm estimating the TDH to be around 55, not 100% sure. The flow rate for the pump filter combo is appropriate. I want to have the juice to run anything and everything I have on the system at will. I also want to reduce the time and effort to maintain the pool. Eventually I will install a salt system. Not because they are amazing in Arizona, but because the wife insists and I don't mind putting the effort in to maintain a salt system. I just can't keep up the daily work and chemical costs. We do have a tree, not ours, the craps in our pool daily.
That was a mind vomit of information, so if you hung in until the end I appreciate you. I just need to figure out the proper size of pipe to offer the best gain and reliability without instigating bother issues and need to know if adding flow meters or gages would help me in the future.
Ps. My new pump will be at least a foot away from the suction line elbow. The filter input and return will have appropriate swept elbows and straight line length prior to bends. Thanks in advance.
CJ
My pool:
- Water feature
- Heater
Current equipment
Return Manifold
Suction to Pump
-2” drain
-2” filter basket
-2” jacuzzi
See photos
CJ
