Hey all, found this site as a result of googling the issues I've had a with a new (to me) pool. I have absolutely no idea what I'm doing regarding pool stuff, but I recently read through pool school and am trying to get started on the TFP method. Grateful for any help you guys can give me. I'll try to be brief but the main issue is I have not been able to hold any chlorine, appears CYA levels are over 100 even after draining.
When I bought the house, pool looked fantastic and took care of it based off previous owners and pool store advice. All looked well, but I wondered why there was very little to no chlorine. Pool store continually told me it just needed more bags of shock, only answer for why it wouldn't hold was that the chlorine gets burned off by the sunlight. It gets sun virtually all day long. I didn't question their sage advice until I ran into an article from this site saying to use liquid chlorine. So I started doing that without understanding the method. I added a gallon of liquid chlorine (from a pool store) once a week. It would shoot the chlorine levels over 10 on my Taylor test kit, but be back to zero within two days. I assumed that would work well enough and did that method for a couple months.
Last month, started having small algae spots, put in more bleach and more and more. Went up to 3 gallons in a couple days and it registered zero when I tested it, which is when I realized there had to be a bigger problem. Water started to get pretty cloudy. Got the water tested at Leslie's, they said CYA was high (200) and that the pool needed to be partially drained. They also said not to use liquid chlorine because that will raise the CYA when its all burned off, while their shock brand won't. That registered as weird to me, which is what led me to actually read through pool school and attempt to fix this.
I read some different threads here and decided to drain a good portion of the pool and refill. I drained about 80-90% of the pool and then refilled with a mix of softened and tap water. After refilled, I tested the levels and added a gallon of bleach.
Numbers:
FC = 1, TC = 1
Ph = 7.8
TA = 200
CH= 250-275
CYA = well over 100 still. When testing, the black dot was no longer visible at about half the way from the 100 mark to bottom of the tube.
Pump runs 10 hours a day.
So I'm at a loss for what to do now. I thought draining would fix the CYA, which means there's something more that I don't understand. I even tested it twice to be sure I didn't screw it up. Did I screw something up on the drain? Instead of shooting in the dark, I figured I'd let you guys set me straight.
Thank you for your help,
Eric
Numbers:
FC = 1, TC = 1
Ph = 7.8
TA = 200
CH= 250-275
Eric
