- Mar 9, 2017
- 141
- Plaster
- Pentair Intellichlor IC-40
If you are at the milky blue stage you are doing great!
Yup, it looks just like I hear it should, milky and blue!
I just wanted to comment that after finding TFP a couple years ago, I always get giddy when we're unable to keep the pool "optimum" due to a personal schedule interference and how quick & easy it is to "clear" the situation! With very little $. TFP is such a great resource and with so much continual learning!...
Much wind and rain for a prolonged period of time, mixed with a lousy work schedule left me falling behind in keeping up with all the tree debris falling into my pool and creating this situation and here I find myself.
Medium green algae can't see the bottom of 3' to 6' pool.
Turn off your SWG. It is masking if CL is being used up by algae. Maintain your shock level with liquid chlorine.
How is your filter pressure?
Absolutely! Following the SLAM exactly.Leave the pump/filter running though.
Pentair Clean and Clear Plus Cartridge Filter CCP-420 So no need.What kind of filter?
De into sand filter if you can baby sit it
Ya, I can take daily photos, good idea. I can see a daily difference though, so that's good.What you can do to help yourself is to take a pic of your pool each day looking down at the same spot. That will allow you to "see" the clearing. Otherwise your eyes will trick you and you will not think it is clearing. This seems like the longest part of the SLAM for most people.
Sounds great!OK,
I think I'm ready to button this up. The morning of day 8 my OCLT finally passed. Tested exactly the same this morning as last night. 0 CL loss. CC tested 0, and my water is clear.
So I'll start letting CL drop to normal levels then re activate the SWG and balance CYA and should be good to go.
Sound right?
FC 21
PH 7.6
CH 360
No Liner, SWG w/Plaster. I dont have that test, I feel confident the CL will drop pretty quickly and I should be able to manage the balance if I stay on it. (Which I will)Sounds great!
Is your pool a vinyl liner? (CH doesn't need to be that high if it is, you don't need to do anything about it, just curious)
Do you have the PH test that neutralizes chlorine first? Otherwise, that PH reading might not be accurate (with FC over 10)
You did a great job!
