This one is harder than a regular above ground. Put some water in it and start filling to about an inch or so. Then put your back to the wall and using your feet, schooch the liner outward evenly around the outer perimeter. Just remember that the more water you put in, the harder it will be to move the wrinkles out. If you want to get on your hands n knees, pull the wrinkles from the center outward and do it evenly... or at least try.
