- May 23, 2015
- 25,693
- Plaster
- Pentair Intellichlor IC-60
One thing - sometimes pool builders are quirky and they just want to build the pool they know how to build and they don’t appreciate customer requests that make them work outside of their comfort zone. This results in all sorts of dumb and bogus excuses being generated for why they can’t do what you’re asking them to do. It’s not every builder but it’s quite common to hear some really “fake but accurate” excuses. The simple fact is this - nowhere in the pool code is it impermissible to hook up an auto fill line to a softened water line. The only requirement that is typically found is that the hookup uses the appropriate pressure reducing and anti-siphon valves. So there should be no push back on this point other than the builder might charge you extra for the hookup if his plumber has to add the additional hardware.
Also, I highly suggest the “dual eliminator” system from WaterTec. It has a granular activated carbon (GAC) tank in combination with the standard softener tank so it removes all chlorine/chloramine from the water. Using the GAC stage also increases the service life of the softener resin as chlorine destroys the resin over time. It’s a little more $$$ but it’s so worth it.
