Wiring SWG to auxiliary on Jandy VS pump
Mexicant11
12
Orlando, FL
I am considering wiring my CircuPool RJ 60 to my Jandy VS pump to come on when the pump comes on. Per the Jandy manual, it looks like I could use one of the two auxiliary relays. Does this wiring schematic seem doable? The most difficult thing would be adding the GFCI breaker to my pool pad panel. I just want to confirm that I would use 2 20 amp breakers at the panel for line 1 and line 2 in lines. The black and white from the CircuPool would be my load 1 and load 2 wires, and the blue would be the ground (according to the CircuPool rep). Any recommendations and advice are welcomed. Thanks in advance.
Wire your SWG to Aux 1. Aux will become hot @ 1725rpm. No need for GFCI if your pump is GFCI protected. I'm on my way home. I'll take a picture of how mine is wired. Give me 30mins
Reactions: Mexicant11
