I am considering wiring my CircuPool RJ 60 to my Jandy VS pump to come on when the pump comes on. Per the Jandy manual, it looks like I could use one of the two auxiliary relays. Does this wiring schematic seem doable? The most difficult thing would be adding the GFCI breaker to my pool pad panel. I just want to confirm that I would use 2 20 amp breakers at the panel for line 1 and line 2 in lines. The black and white from the CircuPool would be my load 1 and load 2 wires, and the blue would be the ground (according to the CircuPool rep). Any recommendations and advice are welcomed. Thanks in advance.
