I live in Maryland and plan to close my pool myself for the first time. Overall, the process seems straightforward except for winterizing the sheer descents pump. I have a dedicated pump located below the waterline that pulls water from a dedicated drain in the deep end. The return is a single pipe into the ground that feeds 4 sheer descents. There is only one valve on the suction side of the pump.
Specific questions: how do I get all the water out? It seems like water could easily get trapped in one of the pipes to a sheer descent because there’s no way to isolate each of the pipes.
Another question: how do I connect my air blower to blow out the suction side? My other pumps have threaded plugs that I can attach my Cyclone. This pump does not. Is there a fitting I can use to the actual pump?
Thanks!
Thanks!
