- May 3, 2014
- 62,696
- Fiberglass
- Pentair Intellichlor IC-40
The 1400 rpm is likely fine. If you are not getting debris falling into the pool, you can eliminate the 2200 rpm for that long. I would break cycle in two for the winter and run it 20 minutes twice a day. This helps clear any air buildup in the system from running the VS at a low rate.
