Hey all,
My cartridge filter finally blew out. It was a no name brand that is original to the pool, the relief valve was epoxied on, and the cartridges were ready to be replaced anyway, so it's been beyond time to replace.
I'm set on using cartridge again. However, I HATE the large 4 cartridge system I currently have. Such a pain to clean that I always put it off. I don't mind cleaning the filters, it's the dumb clamp and o-ring that i struggle with, as the filter is in an awkward place. I'm thinking about downsizing to a single cartridge, 200 sq ft filter. Likely, the pentair. It has 150 gpm max flow rate, which should be fine for my vsp, I think?
My main reason for wanting to switch is the ease in which I can clean the filter. I don't mind cleaning it even monthly if I don't have to wrestle with that dumb clamp. The single filter system just screws on and off. I would rather clean that filter monthly if I had to, than take apart the big boy twice a year. The price difference is also nice, as is the cost of replacing a single filter rather than 4. The extra room in the filter area will also be helpful, as it is tight back there now. Lots of benefits to downsizing, and the only con I currently see is more frequent filter cleanings.
My question is, other than requiring cleaning more often, is there any disadvantage to using a 200 sq ft filter? My pool is 18,000g, vsp that I run just high enough for my swg to generate chlorine. It runs 24/7 in the summer, and less in winter. I also have a solar heater, so the rpms increase enough to get water to the roof.
Thanks in advance!
Thanks in advance!
