No, this is my neighbor's swimming pool, right on our property boundary.I would think it would. Is this your pool?
Strangely, in the other corners, the cement slabs overlap, but only the two corners near the border lack overlapping. I suspect that the cement slabs were not long enough, so they were designed this way to precisely achieve the desired width of the swimming pool. However, I don't think this is reliable.Maybe its not done yet, and they are going to be adding another corner? Or a filler piece.
Not your pool, not your problem ... even if it does leak, it's still your neighbors problem to rectify.
If this is a vinyl liner pool (as most are in the northeast), then the vinyl liner is the water-proofing barrier. The walls are structural in nature. They simply need to hold up against the water volume. You don't build a pool so that everything is water-tight, you build a pool according to engineering plans and if that wall is simply structural, then it is doing its job.
The builder doesn't like being questioned.It definitely looks odd.
Have you gone over to the builder to ask them what's up?
My land is 1.5 meters lower than my neighbor's land, and I don't want the water from their swimming pool to flow to my side.
No, we do not have an HOA. The pool walls have a thickness of only 7 or 8 centimeters, if they can withstand the water pressure? Soil will be filled outside the swimming pool.Do you live an HOA? If so, were the building plans approved by the HOA architectural review committee?
And I don’t blame him …
1. The pool walls have a thickness of only 7 or 8 centimeters, the depth of the pool is 1.5 meter. If they can withstand the water pressure?So, what really started your concern about this pool not being safe?
Are you in some sort of feud with your neighbor where you don't get along?
Have you talked to your neighbor about your concerns?
It does not require licenses to build swimming pools here.You can look up the contractor to see if they have the correct licenses to build pools.
Do you know what licenses are required?
You can also look up the building permit.
The permit should be posted on the property visible from the street.
Can you see this?
