- Jan 20, 2022
- 170
- Vinyl
- Hayward Aqua Rite (T-15)
No. The only change to the water between the two tests was adding the PH reducer. I guess you could consider that the pump was running for an additional few hours before the 2nd test.Remember, the CYA does not change in a short period of time (several months) unless you drain off alot of water and replace with fresh water or add CYA containing products. Have you done either of those things since your last test?
Maybe I just misread the first (or 2nd test)?
