This is a recent thing. All of a sudden my pump can't seem to keep prime. I made sure that the lid is on securely, the basket and skimmer are both clear, and my filter is clean. Am I looking at a suction side plumbing leak?
Most likely, yes.This is a recent thing. All of a sudden my pump can't seem to keep prime. I made sure that the lid is on securely, the basket and skimmer are both clear, and my filter is clean. Am I looking at a suction side plumbing leak?
The pump water level is dropping about half way down during operation. I run my pump constantly so I haven't tried turning it off and letting it sit. I'll report back.Drew,
Tell us why you think the pump is not hold a prime.. What actually happens..
When you shut off the pump, does the pump basket water drain back into the pool, or does the basket stay full of water?
I haven't lubed either - I'll try that.Most likely, yes.
Have you tried lubing the pump lid o-ring? The drain plug o-rings?
Is the water level half way up the skimmer?
The other possibility is an impeller clog. Did this start after vacuuming up a bunch of debris?
Suction Side Air Leaks
If you see air bubbles coming out of the return lines in your pool, you likely have a leak. Some signs that a suction side plumbing leak has occurred include: Read morewww.troublefreepool.com
It may not completely stop flowing but the filter pressure would drop too which is a sign of a suction side clog, impeller or line.Wouldn't an impeller clog cause water to stop flowing?
VSPs often see a small drop or air gap in the pump basket over time, so increasing rpms is common once or twice a day. But if you are dropping halfway down in the basket, it may be more. Be sure to lube those O-rings and while your at it, if it's been a while, be sure the filter carts are clean and not resulting in a bit of resistance or back-pressure from the filter.I should add that this only happens at low speed. When I run the pump at full speed it blows all the air out of the line and it doesn't return.
You read my mind. I just posted that. This is only at low speed. Is it typical to run for a few minutes a day on high?Drew,
I assume you are running at a low RPM...
Do you have the pump ramp up to say 2500 RPM for a few minutes once or twice a day?
