The TA - Further Reading says "TA can be safely lowered as far as 50ppm" but I'm not seeing any description of what could happen if TA is maintained at a lower level. I had a pool installed this summer and initially I was constantly having to use acid to bring my pH down when I had TA levels of 70+. As my TA has dropped lower, I've had to use less acid as expected. More recently, my TA recently dropped down below 50 and it's now been over a month since I've had to add acid which has been nice. So I'd like to try to keep my TA down around 40 if it won't cause problems. What negative effects could I see if I keep my TA lower than 50?
OK, I still haven't needed to add acid but will only add a small amount when the need does arise and retest before adding more to make sure I don't undershoot my target pH.
What pH are you trying to target? When your TA is 50-80, pH should be fairly stable around 7.8-8.0. If, when you get to 50-60, and are trying to lower pH below about 7.8, you will get into the cycle you are describing.
Leave your pH alone if it is between 7.8 and 8.0. When it gets above 8, only lower to 7.8 or 7.9 and you should be fine.
Heaters form a patina of copper oxide, copper hydroxide, copper carbonate, calcium carbonate etc. as the copper gets oxidized and the patina should protect the elemental copper from further oxidation.
At low pH, the patina will not form or if there is a patina, it will be stripped off pretty fast.
So, CSI is only slightly relevant.
High CSI can cause scaling and low CSI might increase corrosion, but pH is more important than CSI.
For fiberglass, the manufacturer will usually require specific levels for everything.
CSI might have some small effect, but probably not a lot of effect.
Low TA means low carbonate, which means low CSI because CSI is a combination of calcium ion levels and carbonate ion levels.
