Hello Jim,N,
VS pumps should get constant AC power, so yes, the line side of the pump filter relay or directly to a circuit breaker.
It should NOT be in external mode which is for relay inputs.
If this is the only pump then it should be set to address #1
If it is not the main pump, then you need to set the address to #2 or at least not number 1.
When the automation is in control of the pump, its screen will flash between Auto and RPM/speed
I have been reading a lot of your posts regarding the serial RS-485 connections and pump capability. I have a Whisperflo VST and Easy Touch 8. PB wired up main power through the relay and using the the speeds on the drive. Like you have mentioned, the power should not be wired through the relays, only the I/O in the cable for external control, or the RS-485. I spoke to Pentair and they referenced page 5 on the manual for controlling 100% over RS-485. The PB's Pentair Rep claims this is not correct and the pump has to be wired the way they did. Do you know for a fact the Whisperflo VST. MN#356289 and Easy Touch are 100% compatible overRS-485 control only. You mentioned a lot of references regarding changing speeds in the spa compared to the pool etc. This looks to be a newer pump. Short of rewiring my self and setting the node and and other data on the drive, not to mention warranty issues, I wanted to get another opinion.
Thanks much!
