Pool details (I can’t edit my signature for some reason and the data in the signature area is incorrect): 22.5 k gallon free form plaster/pebble pool, 1.5 HP Pentair WhisperFlo single speed pump, Pentair FNS DE filter, Aquacal Aerotemp 155 heat pump, 3” tabs or bleach used depending on CYA level. Taylor K2005 test kit for all test except CYA.
So I recently opened our pool to find it had no CYA according to a pool supply place. Last year when closing it the CYA was 77 ppm at the same pool store. I tend to believe the CYA disappeared over the winter and was close to zero because when I added shock the chlorine just disappeared within a few hours. I then added 4 lbs of CYA (should be equivalent to about 22 ppm) and it now tests at 42 ppm at the same pool store. I pre-dissolved the CYA granules in hot water by stirring (and stirring) them in a plastic pail so I believe the 42 ppm test result represents the added CYA.
Last night at dark I added enough shock to bring the chlorine level up to 10 ppm and checked it half an hour later. It only registered 2-3 ppm. New test reagent. This morning I tested it and it’s at zero. That would suggest organics are using up the chlorine. A similar test preformed earlier this week showed that the chlorine level held OK overnight, which would suggest just the opposite. I’m blowing through chlorine like there’s no tomorrow. I count 14 empty one gallon shock jugs (mix of 12.5% and 15%) and 3 empty 8.25% bleach jugs in my garage over 9 days and I have no chlorine in my pool.
Other test results: pH 7.4, TA 110, CH 210. Earlier this week the pool store measured total chlorine of 4.6/free chlorine of 0.4. Next day it was 3.6 and 0.0. That was before adding the CYA and before shocking to what should have been 25 ppm (I didn’t check the level). Yesterday they reported total chlorine of 0.8 and free of 0.3. When I test the water now I don't see much indication of combined chlorine.
I read that bacteria can eat up CYA. I also read that 1 ppm of chlorine should kill bacteria in one hour. So it seems like any bacteria should be long gone.
I should mention that the water itself looks quite good. Earlier this week there was some slight milkiness but that has disappeared.
At this point I’m really focused on getting chlorine to stay in the pool. Suggestions?
