I'm sorry if this is a dumb question. I bought a house recently and never had a pool before. This is an above ground pool with a bottom drain. The 3-way valve is cracked so not only does it leaks, but it takes in air which makes the pump not work properly. I purchased a 3-way valve, I have the necessary adapters and everything, but as soon as I try to unscrew the bottom pipe (which is the one for the bottom drain), water comes out and while I could try to juste change it as fast as possible, that's not exatly ideal since I'd like to make sure I install everything properly and not rush it.
Obviously, it's not really hard to understand why water is coming out since the pressure from the pool pushes the water down the drain... but how do I stop it?
Thank in advance and once again... sorry if this is basic stuff. I've never had a pool before and I didn't even purchase it myself. I came with the house and I'm learning as issues arise.
