+1. No need to pop the cover if it will be a PITA to mix the bleach around. Unless you need an excuse. I feel that if you do and in that case, you need some FC in the pronto. *wink wink*.
If you have any doubts about what is going on in your pool, monitor your FC. Don't guess, testTell me about adding in some chlorine now - we are in similar environments being only an hour away. I'm wondering if i should add some? We plan to open the weekend of April 3...
Without opening the pool and running the pump there's no real way to know true FC content. I'm in the lower Hudson Valley and it's too early for pool opening so I can't imagine in Pa it's any different. You're still one to two weeks away.If you have any doubts about what is going on in your pool, monitor your FC. Don't guess, test
I’ll prob open by end of March like I usually do. But again just me. I figure the less time with the plaster not having balanced water on it the better. I close late and open early.Without opening the pool and running the pump there's no real way to know true FC content. I'm in the lower Hudson Valley and it's too early for pool opening so I can't imagine in Pa it's any different. You're still one to two weeks away.
Agree we Floridians like it in the high 80's80 degrees here today also. 2 more degrees and the cover goes on to keep some of that warmth. We are still too chicken to swim in these temps.
Actually my pool temp is 72 degrees. I had a couple of leaks to repair before I can get the solar kicking in. Hope to get them repaired this weekendOmg boo hoo. Only 80 degrees. My water is 36. Lol
Again boo hoo you!!! LolActually my pool temp is 72 degrees. I had a couple of leaks to repair before I can get the solar kicking in. Hope to get them repaired this weekend
