jeremycrook
- Sep 26, 2016
- 228
- Plaster
- Jandy Truclear / Ei
82 at night and then 83 during the day. I finally figured out how to work my Heat Pump / Chiller. I thought the pool pump HAD to be on to have the Heat Pump / Chiller on. SMH
These units are exactly like our thermostats in our house, set the temp, and walk away... When the pump kicks on, the Heat Pump / Chiller will try to get the water to the temp you set, then turn off.
I was mislead when I built the pool, I was told that I had to run the pool pump 24/7...
