Whats normal pool water evaporation?
markayash
4,644
Atlanta Ga
I have a 15 x 20 kidney shaped pool with a water fall off the spa that runs 24x7 and seem to lose a 1/2" to an inch a day. I should mention in Atlanta it was in the low to mid 90's and my water temp was 85 when I got home..Is this normal?
Evaporation is dependent on wind, humidity, water temperature versus overnight temperatures, etc.
In the summer, I will peak at about 1" loss per day. But my humidity is nearly zero.
Reactions: markayash
Yes, this unnaturally hot May weather here in Georgia has got to be taking a toll on pool water. Evaporation can be expected. Usually I lose the most though in the Indian summer days of fall.
We normally can lose about 1/4 a day with 1/2 inch being on the hottest dry days.
You can prove this and rule out a leak, by performing a bucket test. Just search the forums for how to do one.
Maddie :flower:
You all have been hot, we have been 20-25 deg below normal! It was only in the mid 70's here today. Normal Memorial Day weather can be easily in the low 100's.
Reactions: JoyfulNoise
Surprisingly our weather has been very unseasonably cool. Have had to keep the solar cover on it far longer than every before. High and Low temperatures have been 20-30 deg below normal.
