What to use for SWCG in PoolMath
crosby1612
Active member
Apr 25, 2024
26
richmond VA
Jandy Aquapure 1400
I have a FusionSoft model FSOFT1400 by Zodiac pool systems. I don't see that listed anywhere in the poolmath app in the Free Chlorine section under 24 hour SWG output. What do I use here for the output? Thanks so much
Thank you. When I enter that number, pool math tells me not enough info. What an I doing wrong? I don't want to shock the pool, I just want to know what percent to run the chlorine generator. Thank you again for any help!
To try to clear up the difference between Newdude's and my post, is this your SWG?
.05 lbs per day won't make an appreciable difference for dialing it in. (.2 ppm per 24 hours) (y) I'll happily cede to your 1.25 either way. :)
On that screen you select the %, say 100%, and it tells you how many hours to run the pump to reach your goal.
Or you can toggle it to list hours, say, because you run your pump for 12 hours. So you enter your existing 12 hour runtime and it will tell you to set the cell to X% for that time to reach your target.
