- Jun 22, 2014
- 47,861
- Fiberglass
- CircuPool RJ-45 Plus
Crud, I forgot to do the CC test.. Sorry!
Just tested.. Almost 24 full hours.. FC = 14.5.. Tested it again because I forgot to do CC and it was 16.. {confused}..
CC = 0..
The precision of the measurement is plus or minus one drop when up to 10 drops of titrant are used, or plus or minus 10% of the final reading, when more than 10 drops of titrant are used.
Just tested.. Almost 24 full hours.. FC = 14.5.. Tested it again because I forgot to do CC and it was 16.. {confused}.. CC = 0..
So looking back .... you started your OCLT last night at FC of 17. You said you passed this morning with "barely any loss" - we'll assume an FC of 16. This evening your FC was 14.5 or 16 (two different results). So from this morning until now you lost either 0 ppm or 1.5 ppm of FC. Is that correct? If that's true, it seems to me that you lost very little FC during today's daylight hours which is a good thing. In addition, your last CC was confirmed to be zero. Those are all very good signs. Did I miss anything from your description?
That's correct. Thanks for all the help.
I'm going to bring it up to slam, vacuum one last time, and then drain her down and close it..
