Gang: I have a Pentair Intelliflo VSP and IC40. The pool builder had suggested running the pump 24hrs a day since it's so energy efficient and this would maintain crystal clear water.
I run the pump around 2,000 rpm 7x24 but it triggers low flow error on the IC40.
Questions:
1) Should I run the pump 7x24 and if so, at what speed? Or should I add a higher speed cycle and if so, what speed and how long?
2) Does the SWG still run if it detects low flow?
3) How often do you acid wash your SWG? Mine has never been done (2 MI seasons) but it was never suggested from the PB on open/close that it should be done. I did order the kit though looking at the cell plates they really wasn't any buildup -they looked completely clean.
29K pool with Intelllitouch panel if that helps.
Many thanks!
Questions:
Many thanks!
