- May 3, 2007
- 18,071
- Plaster
- Hayward Aqua Rite (T-15)
Re: What size pipe to plumb my pool and spa?
Bottom line is that the spa MUST be isolated from the pool when heating so it heats quickly and must remain isolated so the water is not cooled off too quickly.
However, other times, when not using the spa, spillover mode, from the pool into the spa and back to the pool, is just fine and a good way to chlorinate the spa water as well as removing floating debris.
I think we went over this before but if you are drawing only from the spa and the spillover is engaged (most controllers do not allow this), then no water will spillover. If you draw from the pool, heat the water and have it spillover, you will be heating the pool and spa to the same temperature.Also, Mark,
Thanks for chiming in since I want to do pretty much what you said was possible, have a spa overflow ability, but valve for how much mixing I want, and when. I think the heater would keep it real hot, even with the overflow on, since the incoming pool water would be mixing with a larger amount of hot spa water even before it goes through the pump, filter, heater, and back to the spa.
Thanks
