- May 3, 2007
- 16,944
- Plaster
- Hayward Aqua Rite (T-15)
Re: What size pipe to plumb my pool and spa?
I have been running mine for over 10 years now with the SWG right after the heater and without any check valve.
With SWGs? I don't believe him. Simply not possible. There is not much FC left over in an SWG after it is turned off. Maybe a rise of 2-3 ppm which is not much more than a recently dosed pool. How does he know the corrosion actually came from the SWG and not just bad water quality management?He said he sees cases there commonly where the heaters were eaten by the chlorine back up because no check valve was installed.
