I would say the same, it lacks the ‘purple’ to be in the 8 - 8.2 range.
Try using one less drop. And an unwinkled white background, the wrinkles add shadows. The second pic seems to have less light but could be image.
I found editing a photo of the comparator really helped me. Like this. Removing the distractions I can see that it lacks the purple.
Oh this is so helpful. I may have to start looking at just each section individually. Thank you!Removing everything but one field i see darker than 7.8. (More pink)
But not quite 8.2. (Less purple)
I use my thumbs to block off the others. You can cut a template from paper or such too.I may have to start looking at just each section individually
You only need it to be close, which, with a little practice you will do fine.I wish there were a slightly more accurate way to measure this!
There are limitations to the tests, but after a little bit you do get better at it.Oh this is so helpful. I may have to start looking at just each section individually. Thank you!
I use the Apera Instruments AI311 Premium Series PH60 Waterproof pH Pocket Tester Kit. It's a digital meter and quickly gives you a very accurate reading. Cost is around $80 from Amazon. I calibrate it about twice a year. I've been using this for the past 5 years and never had an issue.Oh this is so helpful. I may have to start looking at just each section individually. Thank you!
I loaded the pic into Lightroom, masked the sample section and reduced the saturation. I suspect you used too many drops.I find it so hard to differentiate between the 7.8 and 8.2 colors.
Thank you!
