What is the best test kit
decadude
18
Arlingon, TX
I am wanting to take care of my own pool. Everyone says stay clear of Leslies as they are expensive etc
I did buy some chlorine 3 gallon liquid bottles at lowes along with 2 gallons of muratic.
I was wondering what all chemicals do I need to have on deck besides chlorine and muratic acid I have a DE filter
mknauss
13,630
Laughlin, NV
The best value for a test kit is the TF100. Add a Speedstir for easier and more accurate testing.
How are you testing now?
For now, you have the chemicals you need. Once you run your tests with your new kit, post up the results and we can provide more guidance.
mknauss
13,630
Laughlin, NV
Is buying chemicals at lowes and home depot the cheapest route?
Might be. Or might not. Biggest issue in buying liquid chlorine from those big box stores is the freshness of it. Check the Julian date. Look for a printed number on the bottle that starts with 18 or 19. That is the year. The next three numbers are the day of year it was bottled. Best to get it within 60 days of bottling.
Other issue is storage. Those stores tend to store it outside. OK in the winter, detrimental in the summer. Walmart carries Pool Essentials 10% and normally stores it inside. Still check the dates.
Best is finding a janitorial or chemical supply house that will sell it to you in refillable bottles. I think someone has posted about one in Spring, TX. No idea if that is close.
decadude
18
Arlingon, TX
I live in Arlington Texas so if anyone can chime in on the cheapest and is liquid chlorine the way to go for chlorine I am assuming as much based on the previous comments
cfherrman
2,017
Hays, Kansas
The best all around deal is Walmart 6% bleach for $1.77, but you have to lug more jugs around, 6% also keeps outside longer than the higher percentage jugs
setsailsoon
913
Stuart/FL
Deca,
I've now been using the TF 100 since I took over my pool 3 1/2 years ago. At first I wanted to test all the time just to understand my pool as recommended by experts on here. Now I only do full tests once per quarter or so. I do still test FC/CC/PH about 3 times per week. Each pool most definitely is a little different. So I got the XL option - good choice since you get a lot more of the most expensive reagents. Also, once or twice per year they sell refill sets a nice discount. I've found the reagents seem to last at least two years if stored in dark cool dry place so I've only replaced mine once. At two years there was no obvious deterioration but I figured it was a good idea to replace them.
You can get liquid chlorine at places already mentioned but it's worth looking into this also. In Florida Leslie's is the best price usually. They sell refillable 2 1/2 gal jugs that they refill at the store for you. I usually buy it with a coupon at $7.98 for 2 jugs (5 gal). I have friends in Houston that get a similar arrangement from their HASA dealer. When you compare prices be sure to adjust for chlorine content.
Acid is available at hardware stores and big box stores. The best price for me is at Home Depot (2 gal of 31.45% for $11.98). Acid consumption varies mostly on how much aeration I do. Wife likes the spill-over look and sound so we run it a lot and I use 10-20 oz per week. Also, check for strength of the acid. More and more stores are adding/replacing 31.45% with "green" MA which is just lower strength. This is preferred by some because it doesn't fume as much but it takes proportionately more chemical to make the same adjustment. I prefer to handle carefully to make sure I'm clear of fumes and deal with less jugs of MA.
Only other product I kept on-hand is stabilizer (cyanuric acid or CYA) When I used liquid chlorine I kept a small bucket of trichlor tablets on hand for when I would go out of town. You can use this for travel if you do not get too high on the CYA test. CYA lasts so long that I've never had to add any after the initial dose and I keep it in the low end of range so I can use tablets for travel.
Another handy tool you can get is the Pool Math app. It will track everything for you and make it easy to do the calculations for chemical addition.
My 3+ year history for my TFP pool and chems have cost me about $10 per month with this method. Pool has been fantastically sparkling 100% of the time. Wife was very concerned I'd mess the pool up but results spoke for themselves and she quickly gained confidence plus liked the budget benefit.. One neighbor copied me, the others just moan about how much their pool service costs and their pool doesn't look as good as mine.
Along the way I added a LOT of goodies. NG heater, RS 12 w iAqualink pool automation, Solar heat, pool cleaner, and most recently converted to salt water generator. I'm now jug-free and loving it! Got great advice and help from the experts here all along the way. TFP is my pool expert online and it's made pool ownership much more enjoyable for me.
Good luck and please ask any questions you have. There's no reason to wonder if you're doing the right thing or to wait for an obvious problem. People here like to help and love to give you tidbits to avoid problems before they happen.
Chris
Lilypad
132
Plano, Texas
In DFW area Home Depot for muriatic, liquid chlorine at Lowes or Walmart (plain, no additive bleach or they carry Pool Essentials Chlorinating Liquid $3.64). Agree with checking pool supply stores for refillable jugs. Checking freshness date is key. Just saw some of the Pool Essentials at my local Walmart that was almost 7 months old, so make it a habit to look on the bottle.
decadude
18
Arlingon, TX
I thought the status quo on here people were not fans of Leslies but the Leslies refillable jugs I have a Leslies super super close to me like less than a half mile
mknauss
13,630
Laughlin, NV
Liquid chlorine at a great price from anywhere is a good thing.
We just do not trust the pool store testing and really dislike the repackaging of normal household items (baking soda, borax, etc) just to charge higher prices for them.
Reactions: setsailsoon
setsailsoon
913
Stuart/FL
Deca,
What Marty and Kim said! I buy all my liquid from Leslies in the 2.5 gal refillable jugs. It's the best price anywhere near me. But I only by liquid chlorine, noodles, and the occasional part if I need it in a hurry. I don't let them "test for free". If your pool is fine they will often tell you your phosphate level is high and sell you remover. You don't need it! There are a few knowledgeable good people in there but problem is you don't know which one you have until its too late. You've got an armada of experts here with the best advice you can get right here.
Good luck on your pool. Very soon you'll have this down pat and you'll have as much help as you want until you're comfortable going single-handed!
Chris
DJFaninTN
54
Panama City FL
when we had our pool years ago which was chlorine, I found the best bleach prices at Aldi. if you have one near you, might want to check and see. just remember to take your quarter for your basket.
Thread starter Other Threads of Interest Forum Replies Date
kb109 Above Ground Pools 6
A Under Construction 4
B Everything Else 10
