Should I not add anything for the alkalinity?Add chlorine and acid 15 minutes a part.
BTW, your CYA is 60. If the dot disappears between 60 and 50 we round up and call it 60. You cannot eyeball vallues in between the lines since the scale is logarithmic, not linear.
Hey Timm !!
CH is great for plaster
TA will come down on its own when you :
PH - lower to 7.2 with MA and aerate back up. (Might need a 2nd cycle)
FC. Raise with plain Jane bleach.
CYA rounds up to 60 which is a bit high for a liquid chlorine pool. In TX you will probably want it to be 40 once the season ramps up. You can drain about 20% now and let the springtime rain handle the rest, or just maintain a higher FC based on the FC/CYA Levels
If you choose to drain, the fill water will change things slightly so be prepared to adjust again after.
How do I aerate a pool??Hey Timm !!
Lowering the ph and then letting the ph drift back up will lower the TA a little each time. The return jets will make turbulence in the water (aeration) and it’s a natural process. Wind and raindrops can help some too and also kids splashing if it’s warm enough.Should I not add anything for the alkalinity?
Thank you!No, your TA is ok. It will come down over time as you lower your pH.
Aeration - Further Reading
www.troublefreepool.com
Lower Total Alkalinity
A lower Total Alkalinity level can help a pool owner stabalize their pH increase. We'll explain how to lower TA with a little help from muriatic acid.www.troublefreepool.com
Thank you!
Should I re test after adding chlorine and MA?
Also, should I put chlorine in everyday?
If so, how do I find out how much to "maintain" the numbers?
OR do I just put chemicals in once a week or so?
