- May 30, 2009
- 19
- Vinyl
- Liquid Chlorine
I do not have a heater now. I want a gas heater. My pool company is recommending a 250,000 BTU heater for my pool.
I have used a pool heating spreadsheet to estimate that 250,000 BTU will raise my pool 10 degrees in about 7 hrs, and 4 degrees in 4 hrs.
We use the pool on weekends mostly; the pool company is suggesting that I set the heater to 77 during non-use time and increase heating 3-4 hours before use.
? Would it make sense to put in a 400,000 BTU heater instead?
Pros for 400,000 BTU
-Turn it off Monday to Thursday running only on the weekend. Possibly save some fuel costs. I do not know if would be substantial savings or negligible. *(no need to keep pool semi-warm)
- Cooler weekday temperatures would use less chlorine and be a little easier to manage chemistry.
- Ability for swimming earlier and later in the year.
Cons for 400,000 BTU
- Bigger heater is 35%more expensive (+750$cdn) compared to smaller heater.
- Gas Line is more expensive - because it also requires resizing pipe from the gas meter. (+ $cnd)
- Gas is 30 cents cdn per 100 cubic feet, so it will take some time to save enough on gas to recoup extra costs.
Do you recommend getting an over-sized heater for a pool? Did I miss any pros and/or cons?
